06-29-2006 05:18 PM
06-29-2006 07:52 PM
06-30-2006 08:31 AM
Are you talking about the driver on NI's site? If so, then I see quite a bit of documentation. I didn't look at every function but the ones I did look at, had a description for the function and each control and indicator also had a description. You just have to turn on context help to view them. Current driver standards do not require a separate help file and frankly, I wouldn't want one.
The VI called YKWT3000 Application Example1 is single VI that reads and outputs a waveform. Yes, it uses a couple of different subVIs to perform this but breaking down an instrument's commands into a series of subVIs is usually a good thing. For example, you can use the config waveform function just once at the beginning of your program. I think I might have combined the Read Waveform, Read Sample Rate, and Data Convert into one function though. There's a feedback option at the bottom of every download screen. You might want to add any comments you have there. That's the best way to get changes done to a driver.
06-30-2006 11:16 AM
I happen to enjoy wearing egg on my face, thank you very much.
