Why does right click close LabVIEW?
Hello, I am running LabVIEW 8.0 on the NI PXI 1050 and everytime I right click the mouse the program completly shuts down.  The system has been up and running for about 1 month and then today I installed a PXI 6704 analog output and started having the problem.  I need some advice on this problem.
Thanks.
(3,382 Views)
Hi Jmc006,
Another user reported a similar problem to yours on this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=192510
I believe the solution is to remove LabVIEW and ensure that all its registry keys are also removed, followed by reinstalling it.
Message Edited by Anthony_Wong on 06-29-2006 03:30 PM
Anthony Wong
University of Toronto
Chemistry Department
(3,378 Views)
Hello Jmc006,
Look at this link -
http://forums.ni.com/ni/board/message?board.id=170&message.id=162001&view=by_date_ascending&page=1
This talks about exactly the same issue and how it was fixed.
Abhishek
> Thanks.
(3,352 Views)
I once had this problem and it turned out to be a corrupt dir.mnu file in the user.lib directory.  Before you remove and re-install Labview, try deleting the dir.mnu file in both user.lib and vi.lib.  Then restart Labview, it will build these files from scratch.  If this don't work, then remove and re-install Labview.
- tbob
Inventor of the WORM Global
(3,336 Views)
