AVI file is stuck during reading
Hello, I tried to use IMAQ AVI2 read frame to show the video,
However, the screen is always stuck during the process,
in the first, I thought that maybe the reason is about the 2G AVI file bug in LabVIEW,
although I compress it to a file smaller than 2G , the error still happen......
My LabVIEW version is 2014 SP1 (64bit)
(2,862 Views)
Not all toolkits are 64-bit "friendly".  I've only used 32-bit LabVIEW on 64-bit Windows (7 and 10).  I have no problems with opening and playing AVIs.  Do you have (or can you create) a small AVI that fails?  If so, attach it and your code (as a VI, please) and I'll try it ...
(2,809 Views)
