AVI movie from jpeg or bmp
Hi everybody,
I want to create an AVI-movie from jpeg or bmp files. Is that possible with Labview? Does anybody have any examples for that?
Thank you very much,
civil-Ing
(5,627 Views)
This can be done by downloading the NI-IMAQ driver from the following link.
http://digital.ni.com/softlib.nsf/websearch/E289F96B03BDD2AC86256FCB0078B178?opendocument&node=132060_US
After installing the driver you can download the example Imaq_AVI_Processing that illustrates how this is done.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=C0033754BF1F1D3BE034080020E74861
Regards
A Meister
NIDK
(5,616 Views)
Hi again,
thank you for your reply to my question. I have tried the steps you recommended. I also downloaded the Imaq_AVI_Processing.vi. However, when I tried to run it, there were the following sub-Vis missing:
examples\Vision\IMAQ Vision Avi Folder.vi
vi.lib\vision\Avi2.llb\IMAQ Avi Open
vi.lib\vision\Avi2.llb\IMAQ AviGetInfo
vi.lib\vision\Avi2.llb\IMAQ AviReadFrame
vi.lib\vision\Color.llb\IMAQ ExtractSingleColorPlane
vi.lib\vision\Process.llb\IMAQ Threshold
I would be very pleased, if you could help me again.
Thank you,
civil-Ing
(5,579 Views)
You need to purchase Vision Assistant and IMAQ to have this library.
Zaboulou
(5,569 Views)
Sorry. I didnt realize that the example had extra features to it. I will be back with an example on how to write an avi file using only the NI-IMAQ driver (be aware that NI-IMAQ only supports uncompressed AVI formats, so the file created will be big).
Cheers
Meister
(5,567 Views)
Bump
(5,414 Views)
Hello, I have the same problem, but I can't find this example
(4,808 Views)
