Labview 8.2 - Feedback function
I don't understand why the feed back function in Labview 8.2 is not working. I have a very simple problem! All I want to do is read incoming values and upon user's request (a TRUE or False) save one of the incoming values in a buffer for later use. I can do this in 8.5 but I am having problem with 8.2 version. Can you please help!!! It is really bugging me!
(3,468 Views)
We can only tell what you are doing wrong if you show us your code. 😄  (8.5 and 8.2 should be very similar).
(3,465 Views)
What kind of problems?
  • incorrect result?
  • broken wire?
  • program crash?
  • computer crash?
What is different between the 8.2 and 8.5 versions? In think in 8.2 a feedback node cannot stand alone, it needs to be in a loop. Place a one iteration while loop around it.
(3,461 Views)
I think the feedback node can only be used in loop structures in 8.2. Never
use them though, so I'm not sure.
This is because it is derived from a shift register, which only exist in
loops. Only later they realised the loops aren't needed, so in 8.5 you can
use them without loops.
Simply putting a while loop around your code, with the stop condition to
false, should do the trick.
Wiebe.
(3,429 Views)
