Abort All Running VIs
I ran into a probably where I had an infinite loop with a dialog click OK and was unable to stop the program. I found this post that noted you could press ctrl+. and hope it would work:
http://forums.ni.com/ni/board/message?board.id=170&message.id=66917&query.id=77559
One of the users specified that you could create a VI using VI server to abort all running VIs:
http://forums.ni.com/ni/board/message?board.id=170&message.id=66917&query.id=77559#M66917
I tried this, but it didn't seem to work.  I've attached my VI with a screenshot of the code (very simple).  What am I missing?
Message Edited by Derek Price on 05-07-2008 11:36 AM
Message Edited by Derek Price on 05-07-2008 11:37 AM
Message 1 of 13
(11,510 Views)
I think the problem is that your application property node is a direct reference to a specific application, not localhost at port 3363.  Also, you're using All VIs, not Exported VIs.
Message 2 of 13
(11,502 Views)
Hi Derek,
i think the problem is that your vi is the first in the array and so it is the first that will be aborted. Smiley Happy
Mike
Message 3 of 13
(11,500 Views)
You need to exclude your "abort VI" from the list. Otherwise you're stopping yourself.
EDIT: Already answered by Mike while I was composing and posting. I sometimes wish these forums were psychic and would tell me not to bother. Smiley Very Happy
Message Edited by smercurio_fc on 05-07-2008 10:45 AM
Message 4 of 13
(11,497 Views)
I didn't even think of that!  Well, I removed my VI from the list and it still doesn't abort any running VIs.  I get these errors:
Error 1035 occurred at Invoke Node in Abort All Running VIs mod.vi
Possible reason(s):
LabVIEW:  Operation is invalid for this type of VI.
Method Name: Abort VI
Here's the updated VI (using OpenG VI to remove from the VI list array:
So what am I missing now?  🙂
Message Edited by Derek Price on 05-07-2008 01:58 PM
Message 5 of 13
(11,458 Views)
You have a global VI in your list. Can't abort global VIs since they have no code. You can just ignore that error code, or remove global VIs from the list. Your choice.
P.S. You don't really need that OpenG VI in this case. A simple Delete From Array will work just fine. Smiley Wink
Message Edited by smercurio_fc on 05-07-2008 01:30 PM
Message 6 of 13
(11,445 Views)
Using such a mechanism is dangerous...
If you abort one of the sub-VIs of the 'killing' VI you will kill the killer.
One of the options is ctrl-alt-del, cancel on the saving of VI, and don't execute the 'This program won't respond' message from Windows.
Ton
My LabVIEW Ideas
Message 7 of 13
(11,431 Views)
What subVIs? The "killing" VI has no subVIs (if the OpenG VI is replaced with the primitive function.)
Message 8 of 13
(11,426 Views)
Jeff,
What is the difference between All VIs and Exported VIs?  I just tested it and got identical lists.
Jim
LV 2020
Message 9 of 13
(11,405 Views)
The "Exported VIs" refers to the VI Server. From the LabVIEW Help:
Returns a list of exported VIs in memory. This property is similar to the Exported VIs option on the VI Server: Exported VIs page of the Options dialog box.
The VI Server: Exported VIs page has this:
  • Exported VIs—Lists the VIs that can be exported. You also can use the Server:VI Access List property to list programmatically the VIs on the VI Server that are accessible by remote clients.
Message 10 of 13
(11,403 Views)
