About 433 slices for a minimum function?
I designed a simple minimum function, which selects from two numbers the smallest. It needs a MUX and a comparator. When I compile this with LabVIEW FPGA, it generates me 433 Total Slices, 513 Slice Registers and 524 Slice LUTs. I cannot understand why those numbers. When I design it with VHDL in Xilinx I obtain less than 20 slices. Why so huge?
Thank you
Message 1 of 8
(3,324 Views)
Have you tried the max and min function instead?  It's on the comparison palette.
What are your datatypes for the FXP controls?
Are there controls and indicators visible ont he FP of the VI you are compiling?
Message 2 of 8
(3,297 Views)
Accepted by topic author vitrion
LabVIEW adds bits and bobs on top of your code to enforce data flow. You can do things to optimise your code:
The following link may be useful:
http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/using_sctl_optimize_fpga/
Also
http://www.ni.com/white-paper/3749/en
http://digital.ni.com/public.nsf/allkb/311C18E2D635FA338625714700664816?OpenDocument
http://digital.ni.com/public.nsf/allkb/722A9451AE4E23A586257212007DC5FD
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 3 of 8
(3,277 Views)
vitrion,
It's more than just data flow enforcement that is being added in the generation of intermediate files (VHDL).
There's a certain amount of overhead for every application compiled for a National Instruments FPGA target. This includes defining blocks of logic for reserved resources like DMA transfer, PCI bus communication, SPI bus communication (for C-series modules) among other things.
Compile a blank FPGA VI in the context of that project and it will give you an idea of what overhead you should expect in any FPGA VI you compile. That will also let you compare resource utilzation there to the utilzation of your mimimum function and you should get a more accurate estimate of how many slices are being used.
Best,
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
Message 4 of 8
(3,267 Views)
I'd tried with that MINMAX function available in the Comparison Palette, but it's bigger. FXP data is 8-bit without fractional part. Both controls and indicators are visible on the FP.
Message 5 of 8
(3,258 Views)
Thank you very much for the help.
Message 6 of 8
(3,242 Views)
Having controls and indicators on the FP costs extra resources also because you can communicate directly with them.
Message 7 of 8
(3,226 Views)
Several people have already mentioned why the slice count is so high but I figured I'd add my knowledge too.
When the compiler does it's thing it puts components down in a very inefficient way at first.  So adding a U32 indicator to the front panel in this example may take 100 slices.  But as you approach the 100% usage of the hardware the compiler goes back and tries to refactor the code to fit better.  It may take 100 slices to add the first front panel U32, but after you've added 60 you won't have used 6000 slices because the cost won't be linear.  I've seen complations that were over 130% full fit into 100% (well 99%) because of optimization in the compiler.  This refactoring will cost in time as the compilations I've seen will take several hours to get that 130% down to 100%.
Message 8 of 8
(3,205 Views)
