About Boolean property operation
Actually Im having a boolean array,In that i want to change the bolean text (instead of ON & OFF) for each element ,the boolean text may differ for each element
(3,397 Views)
Hi LabVIEW5
i think what you want is not possible. In an array all boolean elements has the same boolean text. Why don´t you continue this thread?
Mike
(3,393 Views)
Hi LabView5,
this question is abou an array and not about booleans Smiley Wink
In an array all element have the same properties - their only difference is the value! No way to change this!
But you can make cluster of booleans with different properties per boolean...
Btw. why do you open new threads when the questions don't change? Stick with your old one!
(3,390 Views)
Or this one .
Stop opening new threads...
(3,365 Views)
