How to get Boolean On and Off text
Hii
    Suppose in one vi i am using Display On and Off text . Now i have to use this On and Off text for other Boolean indicator .so how to get these on and off text....
Message 1 of 15
(5,352 Views)
Hi LavVIEW5,
i can´t follow you. Can you please explain in more detail? Thanks
Mike
Message 2 of 15
(5,348 Views)
See i am having one ini file in that Boolean On and Off text will be available. Now i have to use that On and Off text  for  another set of Boolean  indicators  .....so how  to  get  it
Message 3 of 15
(5,341 Views)
Right-click on the control >> Create >> Property Node >> Boolean Text >> Text
Depending on the direction of the propery node, this will read/write the text for the current state of the control. So you must read/write the text for both states. See attached example.
Message 4 of 15
(5,339 Views)
HI ,
If i have not mistaken you want to transfer the properties of one boolean to the other.
This can be done by using the property nodes of the source and write the same to the target .
Sundar.
Message 5 of 15
(5,344 Views)
Hi
here an example using references.
Mike
Message 6 of 15
(5,340 Views)
hii u have attached me LV 8.5, i am using 8.2
Message 7 of 15
(5,340 Views)
Mike u r using single boolean text for both on and off i am using seperate text for on and off
Message 8 of 15
(5,336 Views)
Hi
sorry you are right. Here is the completed version.
Mike
Message 9 of 15
(5,325 Views)
Here is it in LV8.2.
Message 10 of 15
(5,320 Views)
