About calling dll
rolfk 已写:
It doesn't include all those parameters, only the first!!
And you need to convert LabVIEW strings into Unicode strings in order to pass it to this parameter. LabVIEW strings are 8 bit Multibyte Code Sequences (ASCII for most western locales).
There are routines to do that, namely here! you can also download this with VIPM under the name ni_lib_unicode-2.0.0.4.vip.
With good methods and good tools to make programming so interesting, without your guidance I may be in trouble and will soon give up.
Thanks again for your help.
Message 11 of 15
(1,036 Views)
Hello sir,
I went through your post regarding the initialization of the same dll file.
I facing an issue with loading of the initial command stating unable to find the .CFG file.
Can you please let me know how you were able to overcome the issue.
If possible can you upload the code for initialization?
CLD Using LabVIEW since 2013
Message 12 of 15
(1,000 Views)
Simple test code
Message 13 of 15
(991 Views)
Thank you for the code.
Message 14 of 15
(978 Views)
Did you get any solution on this ?
Message 15 of 15
(896 Views)
