About of image processing with LabVIEW.
Hi all
I made a VI for processing images; i this processing, I work with very images, however the problem is that is necessary choose a Region of interest ( ROI ) in all and this tires the user.
However the ROI is the same in all image. Then I would like kanow if there are same way for define the ROI and thet labview always processing the images without that the user choose the ROI. I need run the program charger the image and get the image processed.
Thanks for your help!!
(2,485 Views)
HI
Here's an example for your reference:https://decibel.ni.com/content/docs/DOC-16485
Best Regards
Diogo Aparecido
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(2,434 Views)
