Error 1162 occurring when deleting menu item
I am trying to create custom menus in the menu bar of a VI in LabVIEW 2010, and consistently receive error 1162 when I try to delete the 'Rename Folder of VIs' entry in the File menu. I can delete the entire menu and add it back to accomplish the deletion, but I intend to retain some of the app-level functions such as 'Save As...'. Does anyone have any idea why this happens? I have tried deleting by name, (both app_Rename Folder of VIs and Rename Folder of VIs) and by number. Neither works. I've attached a screenshot of the VI and the error.
Lenovo Think Center M-series computer (core i7)
running Windows XP
Thanks for any help,
Chuck
(5,194 Views)
Chuck,
You have forgotten to attach the screenshot 🙂
TailOfGon
Certified LabVIEW Architect 2013
(5,193 Views)
Oops! Here it is...
Chuck
(5,188 Views)
It can't find your tag.  Check the tag name in the RTM against your string constant.  There is a mismatch somewhere.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(5,184 Views)
Accepted by topic author Chuck60148
I think it is a tag mismatch too. Try running Get Menu Item Info primitive by specyfing item tag to "app_File", then make sure the output array "submenu tags" includes a string you set to delete.
TailOfGon
(5,177 Views)
Thanks to both of you. That was a good idea. I guess the next question is: How can there be menu items present that don't have menu tags? There are 2 items that don't show up in the tag list, but do show up in the menu: 'Locate in Project...' and 'Rename Folder of VIs...' At least having a list of the tags will make it easier to add back the system entries I want to retain. I can still delete the problem entries by deleting the entire menu and then adding it back, as it does come back empty.
Chuck
(5,153 Views)
The menu items will still show in the RTM without tags.  You must have a tag listed in the RTM selection in order to use it.
(5,150 Views)
