About the counting of true or false condition.
Dear All,
I want all of your corodial help for the attached lab view program.
  • I Want to count the number of true or false condition in a program after each time running.
  • If the condition greater than 5 or 10 iwant generate a message.
  • After the condition true i want to also generate a message but after generating message i did not reset untill close the program.
Please help me about the above problem.
Thanking you
Abu Hanif Md.ripon
M.Sc research student of chittagong University of Science and technology (CUET)
(3,010 Views)
This is a very basic thing. You should use a while loop, and learn what is a shift register. Do not use the "Run Continuos" mode.
If you are a student, you can have access to the Core 1 online training videos. I strongly suggest you to start learning using these freely available sources, before asking here to solve your home work 😉
(2,998 Views)
