reuse data from the input to a sub vi
I hope i can explain this well enough,  i have a subvi that has a string input, it reads the string and processes it. this subvi gets called quite a few times.  each time with a different input, now i need to  call it/run it and have it remember the previous input and merge it with a new input.  i can deal with that part easy enough with a boolean input so i can switch between the current input or the previous input + new input.  its getting the previous input data i am struggling with, i cant read control because it will read the new input i am sending it.  i hope your still with me!
can anyone suggest a way to do this?  i guess i could use a global variable, but i always hear people say to stay away from them.
(3,140 Views)
Perhaps a feedback node is what you're looking for.
(3,137 Views)
I, personally, find feedback nodes more complicated than a "Do Once" While Loop with a Shift Register that "remembers" the previous call.  You make it "do once" by wiring a True constant to its Stop terminal.  Here's a picture (I know, I say "Don't post pictures ...", but I wanted to put in a label ...
I hope this isn't the first time you've seen something like this.  If it is, just try to code it up and run it a few times, putting an indicator on the Shift Register terminal shown as "Last Input".  If you run with Highlight Execution (the little light-bulb) turned on, it should be crystal clear how this works.
Bob Schor
(3,111 Views)
Thanks for your advice, i am fully aware of using the shift register and how you can retrieve the previous data by dragging down the shift register arrow on the riaght hand side.  i cannot use this in the vi i am using.  i have never used a feedback node so i will have a play with that.
thanks
(3,075 Views)
