Absolute time of dynamic data will only show on graph if removing attributes, whereby some data gets lost.
Hi
Using Labview 2011
I have a probleme with rreading some data that I have saved as LVM. format. I have timestamped the data before saving it in a "preprossesing" programe, in which the grahp display is fine. However when reading the saved LVM file the grahp will only display the absolute time if I "remove attributes" from the graph, but thereby it also cuts the last 9/10 of all the waveform-data and in turn displays the data in 1 Hz instead of 10 Hz as saved. If I do not remove attributes and use absolute time it can show all the data.
Hope anyone can help me!!
PS:  (I cannot redo saving in the preprosing programme, cos its a lot of data that have allready been saved this way)
Best Regards
Jesper
(2,450 Views)
Can you share some code?  It's a complete shot in the dark without it.
GCentral
(2,447 Views)
