Accesing PXI_TRIG0 - PXI_TRIG7
I'm trying to access the PXI_TRIG0 - PXI_TRIG7 on the PXI backplane using a 5105 digitizer. Is there an optimal technique for doing this? Something as simple as a toggle control on a front panel that switches PXI_TRIG0 hi and lo would be great. I've tried several approaches without much luck. Thanks.
(3,844 Views)
Howdy jsempsr,
The 5105 can indeed send signals to and receive signals from the PXI_Trig lines. What end goal/functionality do you want to achieve here? I don't believe it's as simple as selecting a PXI_Trig line and setting that line to high or low; rather, you have to route a particular signal to a PXI_Trig line and then have that signal go high or low.
For a list of signals that you can send to the PXI_Trig lines, you may refer to the High-Speed Digitizers Help under the section NI PXI-5105 Routing Matrix. This Help document installs with NI-SCOPE. An online version of this document can also be seen here.
Warm regards,
pBerg
(3,821 Views)
