control checkbox form field in word with report generation toolkit for Microsoft office
Hi all,
Happy New Year!
I insert in the word template the check box form field. It has a bookmark name "Check1".
Now I'm trying to checked or unchecked this field using the report generation toolkit for Microsoft office and I couldn't. If anyone now how to do it? I'm using LabView 8.0
Thanks in advance,
Boris
(4,629 Views)
Boris,
The Microsoft Office Toolkit does not have support for checking/unchecking check box forum field. You would have to research the activex functionality that enables this to be checked or unchecked and then do the activex calls yourself. I did hear of one csutomer who used a special font to write a blank box or a checkbox into a word document and changed it that way as well.
Maybe http://www.ozgrid.com/forum/showthread.php?t=53715 gives a hint to an activex reference
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(4,602 Views)
Accepted by topic author BS1965
Hi all,
After I posted the question I found the way how to do it.
I use macro function to control the checkbox.
Here is the block diagram:
Word CheckBox Control
Boris
(4,598 Views)
Wow, awesome. Sorry I didnt see that searching around! Can you mark your post as solution so future people searching for this can find it?
Thanks!
Rob K
(4,595 Views)
Done.
(4,591 Views)
