Access Report
How can I open a report created in Access by LabView 7.1? I open, edit, delete a register in a field created in Access without problems a database by LB7.1, but I don't know how open a report to print. I'd like to do since To create a report using LabView Tool is very difficult.
(3,689 Views)
Hi Luiz Corrêa.
To open a file wichever the extension, you want to know how is the internal format file, because of the colluns and rows you have, for example.
If you already know, you can read the file using the vi attached that show one step of the completelly vi. I think that it will be useful.
Regards.
Filipe Silva
(3,665 Views)
Filipe,
I can't open your example, I use LabView 7.1. Are You brazilian too?
(3,659 Views)
Olá Luiz , boa tarde.
Sou brasileiro também! Estou mandando o mesmo exemplo por aqui mas só o diagrama de blocos porque eu uso a versão LV8.2 e só consigo salvar o arquivo em um a versão anterior, LV 8.0.
Acredito que assim já se pode ter uma idéia do que eu quis dizer.
In this message you can see the block diagram that was attached before. I can´t save my Vi in LabVIEW 7.0 because my version is 8.2 and i just can save in LabVIEW 8.0. I believe that if you look at the copy of block diagram you will have an ideia about what i´m talking!
Filipe Silva
(3,631 Views)
Obrigado Filipe, "in portuguese" é bem melhor. Vou tentar esse exemplo.
(3,625 Views)
Ok Luiz!
Caso reste dúvidas, manter contato.
Filipe Martarello
Application Engineering
NI Brazil
(3,607 Views)
