Access file on the server with username and password
I have a test program that stores the config file in the local PC,so it is easily changed by anybody.So I would like to store the config file on our factory server.
The PC is login by a very low level acount,so it cannot access the config file.So I would like our IT guy to build a folder on server to store the config file and give permissions to specific acount.So the test program will use these authorized acounts(username+ password) to access the config file.
This is what I am thinking,but I don't know how to do it. How to use a acount to access the file on server in the Labview program?What VIs or functions can be used for this?
(3,386 Views)
If you just do not let others modify the file, you can protect it in another way:
1. Keep the file with the test program;
2. Create a code/decode sub-VI using your owner algorithm;
3. Code the config file and put the password in initial file;
4. Add decode sub-VI in test program, each time you start the test program, it will check the password during initial step, and it will report error if the config file changed;
"I think therefore I am"
(3,367 Views)
Hi!
Here are a few options:
1) You can ask your IT service to put the file on a FTP server and access it (read-only) from your LabviewCode
2) You can ask your IT service to give a read-only access to the file to the low-level PC account. The users can see the file but cannot modify it.
3) You can connect programmatically a network unit with custom credentials: http://lavag.org/topic/13282-filefolder-access-as-a-different-windows-user/ (but I wuold avoid this)
Marco
(3,362 Views)
