check if a system is linear?
I have a problem that I even don't know if it has a solution. I have 2 set of experimental data: Xi(t) (input) and Yi(t) (output). Is there any Labview toolkit that can help me to understand if the physical system giving Y as output if X is the input is a linear system or has some degrees of non-linearities?
I am not at all an expert in signal theory. Further, I have not control on input data (that is I cannot play like I could play with electric circuits changing the input voltage for example). My data are what they are, and I would like to understand if there is some degree of nonlinearity into them.
If you know if there is any toolkit in labview that could help, I would be glad if you could say to me its name.
Thank you
(7,988 Views)
Linear systems are defined by having the following property:  If you know the output F(A) to input A, and know the output F(B) to input B, then if the system is linear, the output to A+B will be F(A) + F(B).  In particular, the output to F(kA) will be kF(A).
Usually when I think about linear systems, I think about systems taking time-varying signals.  For example, a perfectly good linear operator is differentiation, since the derivative d(A+B)/dt = dA/dt + dB/dt.  For this sort of linear system, a property that pops out of the definition is that if you put a sine wave of a certain frequency in, you get out only a sine wave of the same frequency, but possibly with different amplitude and phase.  Thus many such linear systems are characterized by how they handle sine waves of multiple frequencies.
I guess the bottom answer is that you may need to understand a little more about signal theory, and the nature of your data.  Once you have this information, you can probably figure out how to design a test to see if your system is, indeed, linear.
One final note -- almost no system is "linear" -- they all typically "saturate" if you give them too much input, and on the low end, will either have a threshold or an inherent "noise" level that buries the signal when small enough.  So you need to think about how "linear" you need it to be.
BS
(7,975 Views)
Bob, the kudo is because you are s SUPER teacher!!!
Bill
CLD
(Mid-Level minion.)
(7,948 Views)
