Access
Hi all : I need to send data to access database ,, attach see file ,, when I run the vi this error appeared   Does I need to create table at access ?Or after running the vi table will be create automatically ?  Thanks
(3,004 Views)
Look at this
(2,994 Views)
It looks like you are using the database connectivity toolkit. Have you already created a database that you want to write the table to? I would suggest you put a probe on the error line after the open database function. If you open the example finder>>Toolkits and Modules>>Database connectivity>> you will find Create Table Example.vi. This should give you a good starting point. I'm guessing that you need to create a Universal Data Link that you can work from.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,979 Views)
Before you can save data you have to create the tables to hold the data. I would also suggest that you drop the DCT - in the long run it will be a detriment. Check out this thread.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,967 Views)
