How to fix "Project or Library file is corrupt"
Last Time I close the my project, then I want to reopen it, but popup a window "Project or Library file is corrupt"
Can this corrupt project file can be fix?
Because It contain too much information of this project.
By the way, the project file size is 1.4M
and I use LabVIEW 8.2.1 and WinXP SP3
Hope somebody can give the answer, and thank you very much.
Qia
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
(3,717 Views)
Hi Qia,
you can find some posts in the forum, where some users could repair the vi´s using the vi analyzer, but i´m not sure if it also helps you. I recommend to ask the ni support.
Hope it helps.
Mike
Message Edited by MikeS81 on 08-07-2008 09:52 AM
(3,709 Views)
I cannot find the result about this topic.
So I recreate a new project file
Hope there is better solution for this problem
thank you all
QIA
(3,655 Views)
