Accessing Actor Object Data within Event Loop?
@elset191 wrote:
That's what I meant by this paragraph in my first post in this thread
Additionally, I have put references to controls in my class before the branching occurs, and update the value of what I want using that reference.  My accessors then become an unbundle to get the reference, then a value property to get the data I want.  I don't particularly like this method, but it seems to work.
Sorry!  I guess I didn't fully understand what you meant!
Message 21 of 24
(1,290 Views)
@elset191 wrote:
@TailOfGon wrote:
Actually, I like the idea of using the control reference within the object. Imagine you have to change many different attributes of the control within the Actor Core.vi, passing the each attribute to Actore Core will be messy. Having the control reference makes it possible to put everything within method VIs. You can keep the Actor Core.vi clean.
Yes, that's what I've done.  I'm apparently no good at explaining it though.  I know I misused class when I should have said object at least once, which doesn't help.
I think I re-wrote my first post 3 or 4 times trying to clarify what my hang-ups were!  Don't worry about it, this stuff can turn into a semantics nightmare!
Message 22 of 24
(1,288 Views)
Here is something more to think about.
I am a bit of a purist and I do not like sharing data (references) between independent loops.  A control refnum is a reference.  Using a DVR is a reference.  By sharing it, you have given multiple point of control over that reference.  Yes, it is easy but it can get you into trouble.
I like to think about an EventLoop as an actor with a different communication mechanism.  Messages are not pushed to a queue but made into a UserDefinedEvent and signalled on the EventLoop's event ref.  You add that Dynamic Event Terminal and handle the 'user defined event' as if it were a message.
The EventLoop is now a client to the Actor.  It should receive update messages from the Actor.  Processing these updates causes the EventLoop to update the controls.  You can create a map of Actor state values (by name) to control refnum within the EventLoop.  Note that the Actor does not have to broadcast its entire state but can be selective.  An actor that represents a motor might be on or of, have a set speed and an actual speed, and have a direction.  You could pack this up into a single message but you don't need to.
When the EventLoop needs to change the Actor in some way then the EventLoop gets the value from the UI control and package a message up to the actor and as typical with AF Enqueue it.  That message probably will result in some Actor state change and the EventLoop will hear about it.
Now think about the EventLoop as a class, one method in that class contains the LV event structure.  The private data of the class has the mapping between Actor state value and control.  And I can register multiple instance of the same class by sending the Actor the EventLoop instances UserDefinedEvent refnum.  Now a bunch of EventLoops are 'listening' to the same Actor and getting updates.  This seems a bit silly if they are all identical, but what if the EventLoops were actually slightly different.  Maybe one EventLoop shows a historical plot, another shows a grid of data, and yet another shows an animation based on this.  The Actor now knows nothing about how its data is being presented (or values being controlled for that matter), it is only sending updates to anybody that cares and acting on message from anybody that is listening.
One more enhancement, the method vi that contains the LV event stucture can be 'told' where to display itself.  Now I can create a primary user interface with multipl panels.  I 'tell' each one of the metthod vi's to display itself in a specific panel in the primary user interface.  Now I have one window presenting different 'views' of the Actor at the same time.
It is a step, alright maybe a couple steps, beyond the simple EventLoop per Actor. But I am hoping that you all might ponder on ways to maintain data encapsulation instead of sharing common memory.  As a caveat, sometimes there are reasons to share memory most notably performance, but the use case for most Actors I have some across, the publish of discrete data via messages has worked well.
If I was not too clear, let me know.
-Kurt
Message 23 of 24
(1,269 Views)
"Actor Core.vi" is a loop, too. If Logger is an actor, one or more processes need access to Logger's message queue. One way is to keep Logger's queue in the private data of its caller (manager actor, UI actor, etc.), then send Logger's queue to any process that needs to log something.
Message 24 of 24
(1,265 Views)
