Accessing Matlab m-files
MATLAB can access/load an m-file when promped to in the command window.  I was wondering if MATLAB Script in LabVIEW can do anything like that?  I have a MATLAB program that calls on three seperate MATLAB m-files in order to run (each one calls another).  I need a way to call these files at the appropriate times, and I'd like to use LabVIEW to do it.
-Tek
(2,582 Views)
You can right click and import into the script node, but it's not possible (to my knowledge) to import programmatically.
It would make a great product suggestion though!  Click the Contact NI link at ni.com, and then the Feedback Link - I'll suggest it too 🙂
Best Regards,
JLS
Best,
JLS
Sixclear
(2,573 Views)
