10-12-2005 04:03 PM
10-12-2005 04:26 PM
Well LabVIEW has just what you need in the "type def"! The next time you create a enum, right click on it, select create a control go to the front panel, right click on the control and select "Advanced" and then "Customize" to enter the control editor (if you have selected in your front panel "tools", "options", "front panel", "open the control editor with a double click", you can ust double click on the control to enter the control editor). In the control editor you will see a toolbar pull down with the "Control" option. If you pull it down and change to "Type Def" you can modify the control and all copies of it will now get automatically updated, including constants created from the type definition. The strict type def controls the look of the control as well, so it is most often used to make sure that operator interface instances of a control look the same. When you save this new type def it should ask you whether to update all instances, which will update the original control , you will have to go back and make a constant from the new control type to replace that original one, but now every copy made from that one will update when you update the type definition, and you can do that from the constant on the diagram by right clicking and selecting "open type def".
P.M.
10-12-2005 04:38 PM
10-12-2005 10:35 PM
