Accessing VSS Programmatically
Hi!
I want to check out/ check in/ Get latest version the certain folders/ documents/ vis from Microsoft VSS- using LabVIEW program. I am using automation Open function to open session on VSS server. But it is throwing the error message as Error- 2147221164 class not registered.
Which Class (.dll) do I need to register?
Attaching my vi to this message. Is there a better way to do this?
Thanks!
Message 1 of 12
(6,248 Views)
Message 2 of 12
(6,239 Views)
Hi Muks,
Thanks for the link. But which .dll/ .tlb/ .ocx file(s) do I need to register in this case? Where can I locate it?
Message 3 of 12
(6,229 Views)
Yes. Why don't you just use the Source Control VIs?
Message 4 of 12
(6,217 Views)
Hi Smercurio,
I don't have LabVIEW PDS version. I have only FDS version available. Source control VIs work with PDS versions.
Message 5 of 12
(6,199 Views)
Use the following ActiveX class: SourceSafeTypeLib.IVSSDatabase
Ton
Message Edited by TCPlomp on 30-12-2009 07:57 AM
My LabVIEW Ideas
Message 6 of 12
(6,191 Views)
No!.!!...!!!
It returns the same error Smiley Sad
Message 7 of 12
(6,172 Views)
Do you have the ActiveX interface installed (I believe it's an option when installing SourceSafe)
Ton
My LabVIEW Ideas
Message 8 of 12
(6,150 Views)
In your example you use a control, try to use a constant (like my snippet)?
Ton
My LabVIEW Ideas
Message 9 of 12
(6,147 Views)
Hi Ton,
I am not sure whether the ActiveX interface is installed at VSS server. Is there a way to check this and in case it was not selected during installation, can I do some thing now?
I am wondering, why control shouldn't be working where as constant can work!
--ITA
Message 10 of 12
(6,136 Views)
