Accessing VSS Programmatically
I guess you are using the SS.EXE (command line form of VSS) for doing the operation. If thisis the case then you have to register for the same by modifying the Environmental variable found in
Start>>Settings>>Control Panel>>System and press the "Environment Variables" button on the "Advanced" tab.  Find "Path" and append ";[path of win32]" to it.
SS.EXE is located in the "win32"directory under the VSS installation and this "win32" directory must be in your path.
Guru
Regards
Guru (CLA)
Message 11 of 12
(864 Views)
The activeX needs to be installed on the client. I have this running without the SS.exe.
There might be a difference between a control and a constant, but I am not sure.
Ton
My LabVIEW Ideas
Message 12 of 12
(840 Views)
