Accessing the DataSocket only using nids.dll
Hello Candidus,
thank you very much. This really is it.
Honestly speaking, I do not (yet) see the difference to my previous attempts and why I always gotback a variant VT_I4 instead of an VT_ARRAY|VT_R8 (or VT_R4), but since I have a working version I can analyze this , modify it and learn.
Thanks again
 Peter
Message 11 of 14
(1,303 Views)
To all who might be interested:
If I use CoInitialize(NULL) it fails, if I use CoInitializeEx( NULL, COINIT_MULTITHREADED ) it works.:smileysurprised:
Again thanks to Chris and candidus for their help.
 Peter
Message 12 of 14
(1,298 Views)
That seems to be the key.
CoInitialize(NULL) is the same as CoInitializeEx(NULL, COINIT_APARTMENTTHREADED) .
Our DataSocket client can't live in a single-threaded apartment.
That's especially important if you want to use MFC: MFC only supports single-threaded apartments
so you must do your DataSocket stuff from another thread.
Message 13 of 14
(1,294 Views)
The nasty thing was, that it worked for individual data, but it failed for arrays.
Message 14 of 14
(1,283 Views)
