Accomodating 2 byte information into one
Dear Experts,
Assume, I am sending the value of 2 boolean buttons,
                                   1st boolean value being 0, It would occupy 1 byte
                                   2nd boolean value being 1, It would occupy 1 byte
Hence, I will be sending 2 bytes of information. Kindly someone let me know how I can accommodate the value of both boolean buttons into 1 byte of data. Thank you in advance
Message 1 of 11
(3,818 Views)
Accepted by Diaspora
Hi Diaspora,
Build an array from your two boolean values.
Then convert this boolean array to number, then convert the number to U8:
Message 2 of 11
(3,810 Views)
Wow! Thank you for the solution, dear GerdW. I will try implementing the same.
Message 3 of 11
(3,789 Views)
Using one byte, you can send information of up to 8 booleans, of course.
What is on the receiving end? Do you have control over that? How does the other side expect the information?
Message 4 of 11
(3,788 Views)
Dear GerdW, I am able to implement the same. Thank you.
Message 5 of 11
(3,698 Views)
Dear Experts and GerdW,
I tried implementing the same, but my output is differing a bit. As you can see, your output is displayed as follows
But, my output is displayed as follows.
Kindly let me know why this difference is and how to achieve the output representation as yours. Herewith, I attach my vi here. Thank you in advance.
Message 6 of 11
(3,637 Views)
Hi Diaspora,
While I used one TRUE and one FALSE boolean your two booleans are both TRUE…
(Did you take some time to learn about those different display/radix options of numerics? Do you understand how to read numbers formatted and displayed with binary radix?)
On your VI:
Why do you need the local variable? Why do you introduce a race condition?
Why is there no wait function in the loop, so polling for user input as fast as possible?
Message 7 of 11
(3,632 Views)
When I do the same, this is the ouput.
As you can, the radix for binary is chosen.
Message 8 of 11
(3,612 Views)
So you don't think GerdW is an expert? 😋
For the numeric, go into the display settings and change the display format to "%08b".  This will set the minimum length to 8 characters and pad 0s on the the left in a binary format.
For the string, I am not sure what %u will do as that is supposed to be fractional seconds for a timestamp.  Set the format to %08b.
GCentral
Message 9 of 11
(3,604 Views)
Hi crossrulz,
as an expert I can say %u formats an unsigned integer… 😄
Spoiler
I had to look up the LabVIEW help, too, to learn about this format code.
Message 10 of 11
(3,582 Views)
