Accumulating indicator results, and ignoring zero values
Hi dear NI members.
I have been introduced to labview just three days ago by a friend of mine, an electrical engineering student, i wanted to have a computer based monitoring station for my power consumption, he helped me with designing/purchasing the hardware needed to interface the hardware to the PC (Labview), and i ordered a daq which i should have in a few days, meanwhile i am trying to implement the code which i want to use to display the kWh of which i consume, at this point, i was able to figure out how to display the Kwh value of any given voltage and current values, i am stuck at how can i prevent the indicator (kWh) from dropping below the last displayed value ?, since if i change the current input to zero, the whole accumulation goes to zero, as well as any other low value drops the indicator reading significently, below is a video showing my code with annotations further explaining the issue,  please keep in mind i only started using labview three days ago, any help is appreciated,
https://www.youtube.com/watch?v=HmIiCSOrSlU
(4,073 Views)
Hi Emadjaddaa,
attaching a VI here in the forum would be so much better than linking to a video…
What do you expect, when you multiply your data with I=0? Multiplying by zero will result in zero…
You should rething your algorithm!
kWh_current := kWh_previous + I*U*dt
(4,064 Views)
Ofcourse i understand that multiplying by zero will result in a zero, that is my issue, how can i creat some kind of an array which stores each previous data, and only add to it whatever power is being consumed in an hour base 😄
in terms of the formula you have just mentioned, i am assuming ":=" means updated value ?, sorry for my lack of knowledge, but i will give it a shot and post my new code, thank you for now.
(4,048 Views)
Accepted by topic author Emadjaddaa
Hi Emadjaddaa,
learn to use shift registers (aka feedback nodes)!
You should have heard of "pseudo code"…
":=" is a value assignment: "a := b+c" means "let a be the result of b plus c"!
(4,041 Views)
As Gerd shows, you need to multiply before adding (and storing in the feedback node/shift register). Your existing code is flawed because the I and V are global and don't currently enter in the accumulated values.
(4,019 Views)
After concidering your tips, shift registers really are the way to go in such an application, after carefully analyzing the capture you posted, i did the nessecarry adjustments and got it to work perfectly as shown below, thank you for your guidance
(3,996 Views)
