Run .exe in a web broswer
I know of remote panels but thats not exactly what I want. I have a .VI that takes in text from the user on the front panels and then transmitts that text via TCP/IP to message server.
I want the complete vi and all its inner working to be accessiable from the brower. Can it be done?
Message 1 of 8
(4,080 Views)
then what's your problem to use remote panels?
Message 2 of 8
(4,062 Views)
Remote panels means code running on another computer which is not desirable. I want the labview exe to run as a standalone apllication in the browser. I found some material on line that will help me do this so for the moment thanks for the response but I will do some more reading.
Message 3 of 8
(4,040 Views)
The short answer is no.
The longer answer is that if you use WebSockets (in Javascript...nothing to do with LV), which is based on TCP/IP, you can open a connection to a server and write data to it from the browser without any plugins etc. required. It is not possible to run a VI entirely inside a browser (only open a connection to an already running VI).
(blog)
Message 4 of 8
(4,035 Views)
well that is my question answered so. I will re evaluate remote panels. I dont have hige devolper experience so I will avoid the web sockets.
Message 5 of 8
(4,029 Views)
What makes you want it to run within a browser as opposed to a build LabVIEW application that runs in its own window as an .exe?
Message 6 of 8
(4,013 Views)
Well it runs fine as an .exe .The idea was portabilty and ease of use for the customer.Instead of .exe they would just use the browser but given plugins etc its probably just as easy to use the .exe.
Message 7 of 8
(3,982 Views)
I'd say it is much easier to use an EXE.  Application builder makes EXEs, and installers, which can install other components, shortcuts, edit the registry, basically everything you would need to install a program from any source.  Then that EXE and installer can have a version control where version information can link back to source version.  All of this can be done without relying on a specific browser, or plugin, or technology regarding the web which is ever changing.  Sure it relies on other system level dependencies, like .NET, or system calls, but these change much less often.  If your customer is asking for it to be web based, I'd push back and tell them why this idea is not the right approach.  If you are just experimenting and evaluating, then feel free to try other options, like the servers side and remote front panels.
Message 8 of 8
(3,954 Views)
