Acquire RVDT
Hi Ayous,
even though your message is (temporarily) moved into quarantine I will answer your question:
  • The NI9263 is spec'd as ±10V with ±1mA output current MAX
  • Your RVDT is spec'd with a primary input resistance of 20…150 Ohm. This will result in a current of 10V(peak)/20Ohm = 500mA max. (I hope I read the text in the image of your French datasheet correctly.)
I repeat my previous message: read the datasheets!
(And apply basic knowledge for electrical circuits, like Ohm's law and Kirchhoff's rules.)
Message 21 of 26
(1,518 Views)
GerdW,
So, I really don't understand the link between the maximal current of the card and maximal current of the RVDT. In my case, do I need 10V/150Ohm = 66mA minimum to supply my RVDT ? It seems big,
Respectfully,
Message 22 of 26
(1,512 Views)
Hi Ayous,
You need atleast 66mA as those 150Ohm is the upper limit of the input resistance!
@Ayous wrote:
It seems big,
No, this is a usual/typical value for such type of sensors…
Again: apply simple electrical equations (like R=U/I) to the values provided in the datasheets!
Your NI9263 is an AO module used to provide industrial signals (±10V), it's NOT a power supply to drive devices with higher power consumption…
Message 23 of 26
(1,507 Views)
Hi GerdW,
I used your answers to find a solution and I found it.
By using my module's excitation and by recording the VS1, VS2 and excitation signal with 3 different AI of my NI9215, I'm able to compute the phase shift by myself and the re-linearize the sawtooths.
I have a little last question, you said earlier that you do the computation by you own when you acquire RVDT signals, is it possible to do it through FPGA ? Because I'm actually using some VI only disponible through the RT to compute it (RMS computation, peak detector for the phase shift..)
Respectfully;
Message 24 of 26
(1,474 Views)
If you create the exitation with the FPGA , you can sample in phase and you just have to choose the rigth samples for simple decoding.
No need to find peaks.
However, since you have a FPGA you can implement the PLL demodulation proposed in the link of my previous post.
Greetings from Germany
Henrik
LV since v3.1
Message 25 of 26
(1,470 Views)
Hi Henrik,
Sorry for the delay, I was out of the job during 2 months,
Your answer interests me, It seems like I can't use the FPGA to create the excitation because of the electrical limitation of the NI card, but I can acquire this excitation.
So I have, through my FPGA, 3 AI: excitation, VS1 and VS2 which I need to process to compute my angle,
My question is, how can I found the phase between VS1/excitation and VS2/excitation without the peak founder I used in my RT in order to compute the ATAN(A-B/A+B) and relinearize themselves,
Respectfully,
Simon
Message 26 of 26
(1,350 Views)
