Acquire data from sensor via cRIO 9040 port RS 485 MODBUS
Hello everyone,
I am trying to acquire flow rate data from a sensor via the serial port of my cRIO in Labview.
I am using:
  • Labview 2018 (including Real Time  and DSC 2018 modules)
  • RT cRIO 9040 - which includes a serial port RS 485 (https://www.ni.com/docs/en-US/bundle/crio-9040-specs/page/specs.html)
  • Ultrasound flow meter which supports the MODBUS protocol. The interface operates in half duplex mode, 8 data bits, 1 start bit, parity even, 38400k Baud and device address default 001. I only want to read the first holding register 400001.
I read several posts online and I am trying to use a I/O server to do so (https://www.ni.com/docs/en-US/bundle/labview-datalogging-and-supervisory-control-module/page/lvmve/c...)
I can see the RS 485 port as 2-wire connection on NIMAX, I added the modbus serial I/O server (master) from the RT target in my project and I  created the bound variable of interest (flow_data) in my "IO variables" library.
However, when i open the properties of my I/O server I can only pick the serial port in the range COM1 to COM32, which doesn't correspond with the name of my cRIO port I see on NIMAX.
How do I know which one is the correct port?
In my vi I only have the shared variable connected to an indicator.
When I try to run it using one COM port (which I am not sure is the correct one) I get the following error:
-1967353900
Shared Variable in Platform_master.vi<APPEND>
This error or warning occurred while reading the following Shared Variable:
\\.\IO_Variables\Flow_Data
I would really appreciate any suggestion to do so and solve my errors.
Thank you very much.
Gaia
(3,139 Views)
Hey Gaia,
I'll start by saying I'm not too familiar with MODBUS, but I imagine one way to get the COM address of the serial port would be to connect to your cRIO over ssh and list the contents of the /dev/ folder. This should have an entry for the built in serial port.
Can I ask whether you can post your project, or screenshots of it, as this may help troubleshoot this?
Cheers!
Mitch
(3,094 Views)
Hello Mitch,
thank you for your reply.
I attached four screen shots:
1 - NIMAX interface were I can see my cRIO serial ports and their names. the RS 485 is the one I named COM1
2 - My project master. Under IO_variables I have my server I/O "Modbus1" and its bounded variables. I am interested to read a sign integer (input register S300001 or holding register S400001). Here you can also see how I call the variable on my vi (red circle).
with this vi I now get error -1967353902
3 - Screenshot of the properties of my I/O server (you can see that the serial port is COM 1 but as a choice I have COM1-32 and I don't see the visa original name of the cRIO serial port)
4 - As an alternative to the I/O server, I tried to use the modbus library (Flowmeter test 2 vi attached)) . Here I am sure I am using teh correct port because I see its original name. This way I get error 56.
I hope this helps.
Please let me know if you have any suggestion.
Best,
Gaia
(3,078 Views)
