Acquire encoder position with Motion and DAQ
I am trying to acquire an encoder position with Motion. It seems impossible to set the frequency of the acquisition with Motion and I must poll for the position in a do-while loop.
I have read in a lot of threads that one can use RTSI lines to retrieve encoder position with a DAQ Board though it is acquired with a Motion board. But there are no examples at all about this.
To sum up, I need to send Encoder Phase A to RTSI0, Encoder PhaseB to RTSI1 (which I already do), retrieve info with a DAQ device and then calculate rpm.
Christophe
PS: please don't answer with measure angular position.vi or explain me in what this Vi can help me
(3,560 Views)
To be fully accurate :
DAQ : 6230 (i don't see any RTSI terminals, only PFI or trig)
Motion : 7774
Labview 2010
(3,556 Views)
I have managed to read RTSI lines with the counter of my Daq card... but I still have a problem of sample rate since I am using a counter.
I acquire an angular position but I can't derivate it to get velocity since the slopes are identical.
How could I use a user defined frequency? I have thought of using 2 numeric channels of the DAQ but I can't read anything from them
Christophe
(3,529 Views)
Hello.
Could you upload the Measure Angular Position_DAQ.vi  in 8.2 version. thanks
(3,509 Views)
(3,486 Views)
Hi Christophe,
I'm not sure I understood well what you need. You have the angular position and you need to know the timing, am I right? Can you use an other counter on your card to get the period (or the frequency) of your signal? From that, I think you should be able to calculate the velocity.
I hope this helps,
(3,450 Views)
