Which computer sets the time stamp of a shared variable?
Which computer sets the time stamp of a shared variable? The computer that hosts the variable or the computer writing the variable?
(This is important when the system clocks differ.)
Greetings,
shb
(2,648 Views)
Good Question - I have only one use case which is similiar...
I have a cRIO which hosts a NSV library which is bound to a mirror library on the PC.  The PC library
is set to log to a Citadel DB.  When my cRIO RT software writes values to the NSV the timestamp is created
at the instant the write occurs using the RT system clock (which incidentally is sync'd to GPS time).  This timestamp is preverved all
the way up to the PC and the Citadel DB.
(2,601 Views)
Accepted by topic author shb
Hey,
The timestamp is set from the variable who writes.
Christian
(2,582 Views)
This means from the computer which writes the variable and not the computer hosting it, right?
(2,577 Views)
Right!
(2,567 Views)
