Acquire mA continuously and average only when the "average" button is pressed.
I want to acquire 4-20mA from flow meters continuously and show as "live values" and average the live values for a particular period decided by the press of a button. Every time I press the start/stop averaging buttons, the mean value should update to the new mean value.
I did the program using queue and 2 loops and averaging works fine. But once I stop averaging, start averaging won't work again unless I rerun the whole program.
Can someone look into the vi.
Message 1 of 15
(4,469 Views)
Hi Ayoob,
unfortunately you attached your VI in LV2019. Using an older LabVIEW version might get you more audience. (I would like LV2017…)
Basic concept:
  • the producer sends DAQ data into a queue when you want to do averaging.
  • the consumer reads the DAQ data and calculates the average. In case of "TimeOut" (while reading the queue) the average calculation is reset…
Message 2 of 15
(4,454 Views)
Thanks GerdW
Updated the file to LV2016. Can you check now.
Message 3 of 15
(4,442 Views)
Accepted by topic author Ayoob
Hi Ayoob,
use less DDT wires…
When reading multiple channels with multiple samples you should get a 2D array after the DAQAssistent (instead of your 1D array)!
Message 4 of 15
(4,420 Views)
I would always compute the mean, show both in a chart with legend and the operator can select what he wants to see.
(Hint: Make the mean the first channel, looks better 😉 )
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 15
(4,405 Views)
Thanks GerdW,
I was trying to show the number of samples averaged (or tie of averaging). I implemented it using 2 feedback node. It works.
Message 6 of 15
(4,336 Views)
Hi Ayoob,
again you attached your VI just for LV2019…
Wow, that looks complicated!
Why not simply use ArraySize (or MatrixSize) to read the number of samples and add them up using a (read: "one") shift register?
Message 7 of 15
(4,328 Views)
Hi GerdW,
Sorry i forget to change the version.
I knew there will be a better way, but still i tried to find a solution of my own. I tried the array/matrix method also but did not use shift register. I will try that.
Message 8 of 15
(4,310 Views)
Hi Ayoob,
one shift register is enough:
Message 9 of 15
(4,307 Views)
Hi GerdW,
Im facing a problem using this method. It looks like the mean I am getting is a moving average. But what I need is a single average of all values between pressing start and stop the same like what happens in the attached program. Is there any solution for that. I tried many ways but data flow makes the program freeze at different places.
Attached is the first version I made. averaging in this version is good, but in this one when I press the stop button the live reading also stops.
Message 10 of 15
(4,235 Views)
