Acquire video using a port
I'm still pretty new to LabVIEW but with all of my searching I can't find out if what I am trying to accomplish can be done.  I'm working on a project that we need to get the video from a camera live kind of like a webcam.  It goes through a system and then to a computer.  We are using VLC player currently and we have to set it up to read from a certain port.  Everything I have tried hasn't worked yet.  The only actual thing that I have been able to do is play a video on Windows Media Player that is on the computer currently.  Is there anyway to set up a video program in a VI to read from a certain port as long as you have the IP addresses set up correctly?
(3,191 Views)
What kind of camera do you have?
(3,185 Views)
I can't remember the exact model.  It's just like a generic Sony handheld video camera.  We already have a set up that allows us to get the video to the computer through an RS-232 port.
(3,180 Views)
Usually not RS232, would most likely be firewire, analog video, HDMI, etc
(3,173 Views)
Hey STigmata08,
Without more detailed info on your setup, this is the best answer I can give you:
If you have the labview IMAQ software (Image Aquisition), you should be able to set up video to read via tcp/ip or udp. Here's an example program to get you started if you have the required drivers (looks like you just want the client portion).
IMAQdx Video Transfer Using Simple TCP/IP Messaging Protocol (STM)
Cheers!
TJ G
(3,142 Views)
