parameter values to the constructor node
I am trying to understand .net.
For example:
How do I know what parameter string value's can be entered at "categoryName"?(and the other 2)?
gr,
(2,593 Views)
You will have to loop at the documentation for the .Net library that you are using. If this is a published library the API should be documented by the publisher. There is no way to know the correct input values otherwise.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,583 Views)
