Acquiring Data
Greetings,
I'm trying to acquire data from 2 (In the future 3) Analog Input channels. I'm doing this using DAQ assistant.
But I'm running into an error.. I've tried some things, but nothing seems to work. Tried changing the sampling rate and such.
I've added an image of the scheme and error involved.
Thanks in advance!
(4,299 Views)
You haven't tried searching for that error code. Get rid of the second DAQ Assistant and have all channels in one.
(4,295 Views)
That is an extremely common error.
Search the forums for "50103" and you'll find the solution.
(4,292 Views)
Yes, I have found the solutions when I searched for the error.
But the problem is that I want to use multiple DAQ Assistants because I want to show the signals on different graphs.
I'm not quite sure how I could do that with only 1 DAQ Assistant
(4,284 Views)
Accepted by topic author Innervision
You cannot use multiple DAQ assistants.  Use a single DAQ Assistant and use the Split Signal function in the Express >> Signal Manipulation palette.
(4,280 Views)
Thanks for helping me, very much appreciated!
(4,272 Views)
