Acquisition (Scope) saved as TDMS from Labview, why I can't open it with Signal Express 2014?
Like the subject, I saved a TDMS file with acquisition from scope (waveform data type). If i try to import it in Signal Express 2014 nothing appens. Signal Express seems ok due to the fact that i can open other TDMS file.
Any advice?
Thank you very much,
Francesco
P.S.
First time I use the NI Scope hardware. I was able to stream and save 30s of acq with 5MS sampling (I16 Data Type) before memory error, the system is a NI PXI with 4 GB of RAM. Did I reach the system capabilities or I can do better?
(2,760 Views)
Accepted by topic author FM82
Ok got it, to succesfully open a TDMS file in signal express we need to save waveform data type in the write TDMS vi. Maybe this could help someone else.
Regards.
(2,718 Views)
