configuring a network analyzer from a text file
Hello
How can I use Labview to read a configuration mode from a text file and send it to an Agilent network 8720 to configure it?
thank you
(3,098 Views)
Hi linglong,
use text file functions to read your text file. Then use VISA functions to communicate with your device...
(3,078 Views)
Hi Kudos,
Thank you for your reply.
Can you help me with the right VISA function to communicate the text file to the Network?
thank you
(3,025 Views)
Hi linglong,
you will use VISARead and VISAWrite functions.
The commands needed for communication with your device will be found in the manual of your device. Keysight does provide those manuals on their website!
You can also browse the Instrument Driver Network for suitable drivers, there are several available!
(3,018 Views)
