Acquisition from an accelerometer thanks to triggering ?
Hello all,
It's me again. I need help, as always (I'm a begginer with labview and I'm trying to learn by myself).
I got a problem with a software I need to develop for my work: I'm trying to acquire data (vibration) from an accelerometer in order to determine the vibration frequency of an object. Here is the deal: I put my accelerometer on the objet I want to determine the vibration frequency then I excite manually the objet by hitting it and ideally, I record the wave once I hit the objet for a certain period.
My question is then: how can I do that, especially the part about recording from the moment I hit the object for a certain period. For the record, I use a NI USB-9234 with a USB-9162 carrier.
After some digging, I wanted to use a trigger function, the source for the start analog edge would be then the same that the physical channel recorded with a trigger level defined. But, first of all, I don't know if that kind of manipulation is possible. And second of all, apparently, if my USB-9234 card is in a USB carrier, it can not be triggered in hardware (I found this information on the forum). So is that true ? And if so, what can I do to meet the requirements for my software ? I heard about using a software to acquire data over a period of time then parse the desired signal in post processing...
If someboy can help me, that would me mucho appreciated!
Thanks in advance anyway for any answer.
Cheers
(2,919 Views)
Two many messages on this forum!
One hour after writing my message, it is already in page 2!Smiley Wink
Just a litte meesage so my message can be seen by a lot of people...
(2,908 Views)
No one ? :mansad:
(2,892 Views)
Unfortunately, you are right: USB-9234 does not support analog or digital hardware trigger.
So you will have to perform a software triggered finite acquisition (for example an acquisition that starts when you press on a button of the front panel) and then do some signal processing on the acquired data to remove the part with no useful data.
Or you can buy a another chassis / module to be able to perform the hardware trigger.
For additionnal information, please read:
How Can I Trigger a NI 9233 or 9234?
http://digital.ni.com/public.nsf/allkb/4859504F14AF68DB8625721100640F26?OpenDocument
You might find some useful information on this other forum:
http://forums.ni.com/t5/Dynamic-Signal-Acquisition/Is-there-any-plan-to-for-usb-9234-to-support-hard...
Thomas B. | CLAD
National Instruments France
(2,862 Views)
