Re-show the FPGA Successful Compile Report dialog box
Hi, everyone, Could anyone tell me how to re-show the FPGA Successful Compile Report dialog box? I clicked the check box "do not show this massage in the future" on the dialog It won't show up anymore I need to know the accurate onboard clock rates on my FPGA. so the "Target specific properties" can not satisfied me... Is there anyone know how to solve this question? ~~Thank you
(2,619 Views)
To reenable the compile report you must modify LabVIEW's INI file. Make sure the line nirviShowCompileReport=TRUE exists in the ini file. Let us know how that works out!
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,609 Views)
Thank you, Adnan, I tried to add "nirviShowCompileReport=TRUE" into the last line of LabVIEW.ini file. After I complied my fpga vi, the dialog still didn't re-enable. Did i do something wrong? thank you~
(2,600 Views)
I don't have access to FPGA from where I am, so I cannot try it out. But, I will ask you a silly question, after modifying the INI file, did you restart LabVIEW?
Adnan Zafar
(2,586 Views)
