Acquisition problem with labview
Hello everyone,
I'm working on a project. I'm using an arduino board to acquire data from the temperature sensor. But when I launch the acquisition, I get nothing on the labview display. Can you tell me what the problem is? For me, everything looks fine
Merci
(989 Views)
Have you tried the Hobbyist toolkit instead?
BTW, using bytes at port is only required for 1% of the use cases.
https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
Santhosh
Soliton Technologies
(977 Views)
That error usually means another app is using the port. Do you have the serial monitor open in arduino at the same time?
~ Helping pave the path to long-term living and thriving in space. ~
(927 Views)
