Acquisition with PCI-9820 plug in card (ADLINK)
Hello everybody,
I have a PCI-9820 card which is connected to the laptop ,it has 2 analogue channel.
So, i'm a beginner i want to do the acquisition of the signal with Labview ,and i don't find any examples of that .
i will appreciate any help .
Thank you
(3,162 Views)
The PCI-9820 card can be used with LabVIEW by using the driver DAQPilot developed by the manufacturer of the card according to its datasheet (https://www.contradata.it/upload/allegati/PCI_9820.pdf).
The driver contains examples showing to use the PCI-9820.
Best regards
(3,129 Views)
thanks for your respond , I had some problem of installation with DAQPilot when i open the examples LABVIEW doesn't recongnize the blocs of DAQPilot ,But now i found another Driver called DAQ-LVIEW plus 64 bits and it seems to work with the card using the examples .
i'm wondering if i should continue to use DAQ-LVIEW or i must use DAQPilot , and if there is any references that can help me to work with the card and have more information .
Thank you
(3,127 Views)
What did you do with the DAQ-LVIEW file to get LabVIEW to see your card? I have downloaded DAQ-LVIEW-plus file (ADLINK website) for my PCIe-9814 card, but it is not a valid file in Call Library Function Node.
(3,073 Views)
