Lokking for Database Toolkits
Hello everybody,
I'm looking for a Database Toolkit for no particulary DB. Probably mySQL over odbc, but shure it has to be 64bit. I'm very surprised that I can't find very much. Here are my results until now:
  1. ADO Toolkit or here
  2. LabView Database Library
  3. LabVIEW SQL Toolkit von halvorsen
  4. NI Database Connectivity Toolkit
  5. Database Connectivity Toolkit für schnelle Datenbank-Transaktionen von Ovak Technologies
  6. GDataBase for MySQL
  7. LabSQL
1. Seems to have all basic functionality, but no support and it's not under development any longer.
2. I can't get it to work with 64 bit.
3. Similar to 1.
4. Would be our first Option - but doesn't support 64bit, so it's out. What does NI think to not support 64bit?
5. Nice - you can convert the variant after a select to a typedef Cluster
6. Seems to have most of extra functions, like transactions and conversions (UTF8 <-> String, Timestamp <-> date string). Unfortunatly the evaluation version won't connect to my test mySQL Server, so I can't test it more deeply
7. I've read this term often in forums - but all links are broken, so it seems to be dead.
Are there other Toolkits out? What Toolkit should I choose? What are your experiences? Thanks for any ideas!
Cheers, Alex
It's a crosspost
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
(3,150 Views)
Hi AlexElb,
Since LabVIEW 2019 the Database Connectivity Toolkit supports 64bit.
Missing NI LabVIEW Database Connectivity Toolkit in LabVIEW 64-Bit
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,098 Views)
