Acrobat Reader 11.0.07 update causes LabVIEW application to crash
Hi All,
I wrote an application that uses the Adobe ActiveX element to display a PDF.
This code used to work fine, but when I updated my acrobat reader from 11.0.06 to 11.0.07 it causes the application to start very briefly displaying the icon in the taskbar but then close (without an error or warning notification).
When downgrading to 10.0.06 the problem was solved.
Perhaps this can be of help for others who are experiencing problems with LabVIEW / Acrobat Reader.
Chris
(3,706 Views)
This is the related link on adobe forum
https://forums.adobe.com/thread/1474715
Regards
Golzio
(3,687 Views)
I hesitated to add this comment, but this works for opening PDFs.
Jim
(3,678 Views)
This is a known problem that everybody is yelling about and the solution is to not upgrade to 11.0.07. You don't have to all the way back to V10. 11.0.06 works fine. Just remember to configure Acrobat to not automatically update itself.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,653 Views)
Hi Chris.
We are well aware of the problem. We have documented it as CAR#480386.
You can also find the official response from Adobe in this link:
The AcroPDF.PDF Class is no longer accessible from VisualBasic6 after update 11.0.0.7.
So for now, I would advise you to use Adobe 11.0.06.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(3,641 Views)
Sometimes I used this solution proposed by Jim (open PDF in browser) but I will prefer avoid browser because It is slower than activex and also methods from activex are missing.
Regards
Golzio
(3,604 Views)
