Active X Container System Modal
Hello
I have placed an Active X Container on my front pannel.  I have inserted the Microsoft Forms 2.0 Scrollbar into the container.  If I change the windows behavior in vi properties to modal and run the vi the Active X container disapears.
Does anyone know why this happens?
Please Advise
Dan Shangraw, P.E.
Message 1 of 11
(4,976 Views)
Hi Dan,
I tried reproducing the behavior that you experienced, but was unable to.  I simply created an ActiveX container, inserted the Microsoft Forms 2.0 Scrollbar, changed the windows behavior in VI Properties to modal, and then ran the code. What version of LabVIEW are you using? The example I created was in LabVIEW 7.1.
Best Regards,
Jonathan N.
Message 2 of 11
(4,956 Views)
I am using LabVIEW version 7.1
Dan Shangraw, P.E.
Message 3 of 11
(4,953 Views)
Here is the vi I created
Dan Shangraw, P.E.
Message 4 of 11
(4,953 Views)
Hi Dan,
I opened your VI and your right, I couldn't see the scrollbar on the front panel. However, if you just copy and paste the scrollbar from the block diagram view, everything works fine and the copied scrollbar is visible. I ran the program in the modal mode with the copied scrollbar and it worked fine. I am going to attach my program that has the scrollbar visible. See if you can run it without any problems.
Best Regards,
Jonathan N.
Message 5 of 11
(4,945 Views)
It would help if I attach the VI.
Jonathan N.
Message 6 of 11
(4,943 Views)
Your VI has the same problem as the one I submitted.
Dan
Dan Shangraw, P.E.
Message 7 of 11
(4,935 Views)
Hi Dan,
That behavior we have been seeing apparently was a bug in LabVIEW 7.1 but has been fixed in LabVIEW 8. I just tested that feature out and it has been fixed. LabVIEW 8 is now available to download and demo at LabVIEW 8 Demo.
Best Regards,
Jonathan N.
Message 8 of 11
(4,929 Views)
Hi Dan,
If you are looking for alternatives beside LabVIEW 8, check out the KnowledgeBase called Microsoft Forms 2.0 ActiveX Controls Disappear after Closing and Reopening a VI.
Hope this helps!
Best Regards,
Jonathan N.
Message 9 of 11
(4,921 Views)
Thanks Jonathan,
That did the trick
Hopefully NI will include a scroll bar control in future versions of LabVIEW
Dan
Dan Shangraw, P.E.
Message 10 of 11
(4,911 Views)
