Active X and Vector CANoe
I want to use the LabView ActiveX VI's to control Vecotr CANoe(v5.2) and I'm not sure what to do.  I can launch the application and load a configuration file.   I want to do a mass compile, but the CAPL property returned from the application is a variant.  What do I need to do to utilize the other CANoe methods?
Tom
(7,956 Views)
Greetings!
   Vector will be the best resource to confirm the specific API they have for LabVIEW to communicate to the CANoe. I found a few links that might be useful -
http://forums.ni.com/ni/board/message?board.id=30&message.id=743&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=30&message.id=1048&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=16894&requireLogin=False
Thanks and hope this helps
Best regards
Avi Harjani
(7,937 Views)
