call library function using array pointer
Hi,everybody.
Now I 'm using LV 8.0 to develop a  driver for my  DAQ.Right now I have the  Driver with APIs.So I intend to use the "CallLibralyFuncion" VI .BUt When I test it,the problem appears.
The first function I need to cal is "ScanDevice" function,with the details below:
Inputs:1.CardNumArray,a long type array for storing the returned card IDs,passed by pointer.
            2.CardNumArrayLength,tell the function the size of the array.
Return:The found Card count or error codes.
So I created the VI as show the file I given.
Then the problem appeared:There is always a application error :
It shown me some memory can't not be written.Is it mead I need pass a traditional pointer as in C ,Can the value of the control be used as a buffer to storing the return imformations?Or I need to do other work for calling this function.
Can anyone show me how to use "CallLibralyFuncion" to call my "ScanDevice" function?
(3,363 Views)
hi there
well, some wild guesses:
- is CardNumArrayLength the number of elements or the number of bytes? if number of bytes pass the number of elements multiplied by 4 to the dll
- try to use a constant U32 array as databuffer
- set the calling convention of the dll to "stdcall (WINAPI)"
- set the execution mode of the dll to "Runin UI thread"
please also post the dll here
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,358 Views)
Nice help,sir,thanks a lot.
Actually I just forgot how to spell the word "elements" yestarday,It looks to be some not good :).
The dll file is hardware based and there is a kernel dirver too.So only dll file may show no effect.
Here is the file.
(3,342 Views)
Oh,my god,I have forgot to tell you that it works fine now.:)
So,thanks a lot again.
(3,337 Views)
